McCloud Dual Disk Clutch Experience
Old Sep 13, 2001 | 12:02 AM
Skeeter1's Avatar
Skeeter1
Default McCloud Dual Disk Clutch Experience
please discribe your EXPERIENCE, I'm thinking about having one installed
Old Sep 13, 2001 | 01:02 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: McCloud Dual Disk Clutch Experience (Skeeter1)
It took 5 weeks to get my clutch assembly and took another 5 weeks to get my Adjustable Master. Once I got it all together It works great! Grabs much better than the single disk ever did. I had the OEM unit and another Single Disk McLeod before. You will have to get the entire setup to make it work
Flwyheel, clutch assembly, pressure plate, Z06 Slave & Adjustable Master Cylinder...
I went with the Aluminum Flywheel and I really like it.
vetterdstr
Old Sep 13, 2001 | 02:01 AM
Mell's Avatar
Mell
Mine is working fantastic. Good pedal feel with the AP master also. All is well.
Mell
Old Sep 13, 2001 | 02:48 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Well... Short story, works great! Long story, TOO LONG!!! Just make sure you have the Zo6 slave, and the adustable master without the restriction in the line or the clutch may hang up on high RPM shifts. Mcloed may or may not have taken care of the restricter by now,but keith at corvette connections,941-274-6840, can help you with an AP adustable Master and a restricterless line. I got mine from him awhile ago and did'nt find out about the restrictor in the Banjo bolt right away. I have since had that drilled out and now have a very functional duel disk.
JB
Old Sep 13, 2001 | 02:51 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Failed Mcleod parts:
3 single disc clutches
1 twin disc clutch
2 billet masters
Total cost to me = $5000.00+
Total miles driven = < 3000
Old Sep 13, 2001 | 09:02 AM
vetterdstr's Avatar
vetterdstr
Default Re: McCloud Dual Disk Clutch Experience (Godspeed)
Hey thats quite a sig you got there!! When did all these problems with the McLeod assemblies happen?
vetterdstr
Old Sep 13, 2001 | 12:49 PM
Godspeed's Avatar
Godspeed
Senior Member
Default Re: McCloud Dual Disk Clutch Experience (vetterdstr)
I worked with the Mcleod products from mid 99 to early 01 and never had a working reliable combo that could hold any power. The singles would give out around the 415RWHP level and the twin disc never worked despite countless hours of labor and using various mcleod masters that all failed. Also Mcleod would not answer there phone 99% of the time when I tried to call them - just the service you would expect for over 1200 dollar clutches that don't work.
I have not tried the Cartek clutch, but the best clutch for me so far has been the Star Stage 3 with a ceramic disc using new stock hydraulics. This is what I'll probably install when I put the 422 in the C5, but I've also heard really good things about the Cartek clutch.
-Jeremy
Old Sep 24, 2001 | 08:37 PM
Dave H's Avatar
Dave H
Cartek Clutch=Awesome (Schweeeet for you younger guys!) Just be sure to go with a new slave and adjustable master and do a careful install including facing the flywheel. But you all knew that anyway............. :D :D :D
Old Sep 24, 2001 | 10:10 PM
vette-crazy's Avatar
vette-crazy
I didn't vote because my experience is with the single disc.
However, Jason at http://www.moreperformanceinc.com has the dual disc in his Vette with the 427 and in his F-body with about 700 RWHP. He uses the same master as I do (the AP Racing adj master). Mcleod, AP adj. master, Goodridge braided line (to eliminate the restriction), Z06 slave...this is a great combination. This kid dumps the power to it. Don't wate your time w/ the Mcleod master. It is not worth looking at.
Old Sep 25, 2001 | 01:58 PM
J Z06's Avatar
J Z06
1 twin disc clutch
2 billet masters
That is horrible.
To McCloud Dual Disk Clutch Experience
