Transmission Noise?
Old Sep 13, 2001 | 12:15 AM
DC5's Avatar
DC5
Default Transmission Noise?
Have any of you A4 owners ever experience a noise from the transmission that I can only describe as a “growling” sound. This is starting to happen now sporadically but when it does, I’m always at a stop light, in gear with the brakes engaged. When I shift to neutral, the noise obviously stops. Sounds to me as though 1st gear is trying to engage even though the brakes are on.
Any thoughts on what might be causing this? Of course, my 3-year warranty has just expired. BTW, its a 3:15.
Thanks!
Old Sep 13, 2001 | 07:06 AM
c4c5specialist's Avatar
c4c5specialist
Cruise-In II Veteran
Default Re: Transmission Noise? (DC5)
Hi there,
I would first check your fluid level, as you may be low on fluid and your tranmission oil pump is cavitating.
Let us know how you make out, c4c5
Old Sep 15, 2001 | 06:14 PM
Tiger Shark's Avatar
Tiger Shark
Did you get your problem resolved?
Old Sep 18, 2001 | 12:10 AM
DC5's Avatar
DC5
Default Re: Transmission Noise? (TargaC5)
Haven't checked the level yet. Stock owner's manual doesn't say squat about procedure to check the transmission fluid level. Anyone care to share any tips for checking the level?
Thanks.
Old Sep 18, 2001 | 11:36 AM
sbkim's Avatar
sbkim
Are you sure it isn't coming from the differential? I had similar noise coming from the rear. The dealer will be replacing my diff. soon.
Old Sep 19, 2001 | 02:48 PM
Tiger Shark
Default Re: Transmission Noise? (sbkim)
I'm not sure about how to check your transmission fluid on an A4. That's strange they wouldn't have made it owner-accessible like most cars.
Any of you A4 guys know?
[Modified by TargaC5, 12:49 PM 9/19/2001]
Old Sep 19, 2001 | 04:23 PM
blackjack's Avatar
blackjack
You must lift the car and level it. With the engine running and the tranny temp roughly between 100 and 130 degrees, remove the drain/fill plug on the driver side of the tranny pan. Fluid should be level with the bottom of the drain/fill hole. Add or drain accordingly. DO NOT turn the engine off with the plug removed or you will loose a couple of quarts of fluid. Every 3,000 mi when I change the oil I drain the tranny with a small pump and refill. I only swap about 3 quarts but it helps kepp the fluid fresh. I do filter and pan removal every 10,000 mi and that allows a 5 quart swap.
Hope this helps...
:flag Blackjack :flag
Old Sep 19, 2001 | 04:27 PM
RedLandRocket's Avatar
RedLandRocket
Default Re: Transmission Noise? (blackjack)
Blackjack,
When you do the 3 quart swap do you drain it with the engine off and then refill it with the engine on?
Old Sep 24, 2001 | 03:30 PM
C5NBM's Avatar
C5NBM
Mines having a whinning noise...bringing in the dealer tomorrow. I'll let you know what they find
To Transmission Noise?
