pulley help please
Old Sep 17, 2006 | 03:42 PM
tripod5's Avatar
tripod5
Default pulley help please
My a/c tensioner and idler pulley seem like the bearing is shot on both of them. I changed the serpentine belt idler and tensioner pulley, but i can't seem to locate at any store that sells the ac tensioner and idler pulley. Can someone please tell me the part #. Thank you
Old Sep 17, 2006 | 03:50 PM
double-oh-coupe's Avatar
double-oh-coupe
I got mine from Fred Beans ... PNs as supplied by Gene are:
Hi Chris,
The tensioner is part number 12560345 and the idler is part number 12557334.
Thanks!
Gene.
Old Sep 17, 2006 | 03:58 PM
tripod5's Avatar
tripod5
Am i correct by saying the tensioner pulley and idler pulley are the same on the a/c belt system, because they look the same. On the serpentine system they are different, because 1 has ribs and the other 1 is smooth.
Old Sep 17, 2006 | 04:24 PM
double-oh-coupe
Correct -- the pulleys themselves are the same. But, for whatever reasons, GM sells the idler pulley as the pulley by itself, and the tensioner pulley as an assembly (i.e., the pulley along with the tensioner/spring device). Hence the two part numbers.
Old Sep 18, 2006 | 07:24 AM
tripod5's Avatar
tripod5
Thanks for the reply double oh coupe. I will then purchase 2 idler pulleys,because the tensioner seems fine.
To pulley help please
