Gears Question, please help!!!!!!
Old Sep 17, 2006 | 06:00 PM
karpetcm's Avatar
karpetcm
Default Gears Question, please help!!!!!!
i had 2:73 gears on my 93 Camaro Z28 6 speed manual tranny. I dynoed at 278.00 rwhp with every bolt on. I dynoed a second time with those same gears again at the same numbers pretty much. I changed to 3:42 gears and only that mod i dynoed lower to 266.00 rwhp lost 12rwhp. Ive heard from several people that you lose rwhp on the dyno due to gears but why ? and do you really lose rwhp ? why cant the dyno compensate for the gear swap and give you correct rwhp numbers. Can anyone help please ! ! !
Old Sep 17, 2006 | 06:29 PM
Mike Mercury's Avatar
Mike Mercury
dyno numbers
How has the car changed at the 1/4 mile dragstrip with the new gears ?
Old Sep 17, 2006 | 06:44 PM
karpetcm's Avatar
karpetcm
Im half a second quicker with way more wheelspin, no traction in 1st, 2nd and most of 3rd and an extra shift goin to 4th. Before with the 3:42's i would end the quarter mile in 3rd gear now its 4th. Its a huge improvement but with my aluminum flywheel and stage 3 clutch revs are fast shifts are hard. With better street tires even i would have much better times let alone drag radials.
Old Sep 17, 2006 | 06:47 PM
mfrejek's Avatar
mfrejek
Originally Posted by Mike Mercury
dyno numbers
Sounds like you get your traction problems under control and you'll be smiling
To Gears Question, please help!!!!!!
