Engine Replacement for a C5 - Need some advice please!
Old Sep 17, 2006 | 08:56 PM
maddog's Avatar
maddog
Default Engine Replacement for a C5 - Need some advice please!
How are ya'll?
Anyways, I've got a Nassau '99 FRC currently running 94K miles with quite a bit of custom mods...The car runs great now and is in great shape but I put about 23K miles on it a year and know in the future it'll need some work...the point is I really would like to keep the car going if that's a realistic idea (let me know if my thoughts are right) after the engine goes...
I've replaced a few parts here and there but my thoughts are to run the car until it gives and then swap for a new engine (likely a 383), get that tuned with a nice heads/cam package, and keep going. Any idea an estimated cost for a swap like his and what other parts to the car should I worry about redoing if I want to keep the car? Is swapping the engine when the stock engine dies a proper way to rebirth the car? I understand life wear of other parts, but other than cosmetics, what other parts would I need to attend to to make the mechanicability of the car "~like new"?
I'm a little lost on this issue but thanks a ton for any advice!
Matthew
Old Sep 18, 2006 | 12:11 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
If the car has otherwise been reliable, I see no problem with your plan. When the time comes, it would probably also be a good idea to replace the suspension bushings and get the transmission serviced.
