6th Gear Troubles
Old Sep 18, 2006 | 06:56 PM
Doc Holiday's Avatar
Doc Holiday
2nd Gear
Default 6th Gear Troubles
I have a 1999 C5 with 16,000 miles. It has a 6 speed manual transmission that, as of recently, will not grab 6th gear. I am able to "fake it out" occassionally by shifting to 4th and back over to 6th. When it does go into 6th, it stays in without any noise or additional problems.
Has anyone ever experienced a similar issue and what was the cause / resolution? Also, does anyone know a reliable transmission guy in the Chicagoland area that would be able to accurately diagnose and repair without taking me to the cleaners??
Thanks for the support!!
Doc Holiday
Old Sep 18, 2006 | 07:16 PM
DirteeDave's Avatar
DirteeDave
Stock or aftermarket shifter? If its aftermarket, specifically a Hurst, it could be a problem with the adjustable stops, although the problem would probably affect 2nd and 4th also.
Old Sep 18, 2006 | 08:49 PM
JH's Avatar
JH
Gee, Doc, if you have been ham-fisted hammering that shifter, it can happen. Good luck, you're gonna need it.
Old Sep 18, 2006 | 09:03 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
My educated guess is that you have damaged/smashed shift fork pads. Give us a call for repair pricing. 1-800-406-1109
www.RPMTransmissions.com
To 6th Gear Troubles
