exhaust help
Old Sep 20, 2006 | 05:14 PM
lenbal's Avatar
lenbal
Default exhaust help
HI
I own an 01 automatic.. had to please the wife
I have a corsa pro-touring exhaust with a corsa x pipe and stock cats. I would like to put on long tube headers with out welding, cutting, lifting engine and removing half the parts if possible. I have seen the Bassani headers and they are a snap to put on but dont know if they will bolt to existing cats, sensors will work or need new cats. Any long tube would make it sound nice and go faster but have limited work area and tools. I'm not stuck on the Bassani except they are really easy to install - open to suggestions of other brands. Also dont know about codes and tune if required after install.
Any help or suggestions will be welcome. I talked to the companies and they are not sure about mixing parts, understand if I had one company from front to rear there would be no problem but mixing is causing the problem.
Thanks Len
Old Sep 20, 2006 | 08:57 PM
fastdriver1's Avatar
fastdriver1
Give Carmine at The Vette Doctors (supporting Vendor) a call. I'm sure he can lead you to the right set up.
Tony
Old Sep 20, 2006 | 09:16 PM
lenbal's Avatar
lenbal
Thx will call them in the morning
Len
To exhaust help
