HELP!! Question: About Brake Squeal Fix?
Old Sep 21, 2006 | 07:56 PM
opmope's Avatar
opmope
Default HELP!! Question: About Brake Squeal Fix?
Have 2003 50th Ann.Vert Auto.3755 miles and my RR brake is squealing!Should I take the car to the dealer or has someone experienced this before and knows how to fix this?Is it an easy fix?I tried washing it out with water pressure.I tried driving it thinking it might clear itself.Just seems to be getting worse.Any suggestions.Dave
Old Sep 21, 2006 | 08:29 PM
jimchris76's Avatar
jimchris76
All you need to do is bed your brakes.
Old Sep 21, 2006 | 10:09 PM
on3r's Avatar
on3r
pressure washer? lol
take it to the dealer...it's still under warranty i'm assuming? the dealership i work at would probably do it for free because of the low mileage (if its under warranty)
there's also this stuff called saBesto Brake Finishing Treatment...its a metallic spray that you coat your rotor with...it fills in little slots in the rotors to reduce/stop squeaking...but be careful with it because it's almost like spray paint so cover the wheel well area before doing it if you do take that route
Old Sep 21, 2006 | 10:22 PM
runwhatchabrung's Avatar
runwhatchabrung
id recommend taking it to someone else to work on since you cant even seem to find the right section to post this in.
Old Sep 22, 2006 | 12:30 AM
opmope's Avatar
opmope
How do you bed your brakes?
To HELP!! Question: About Brake Squeal Fix?
