SLP Pulley Install
Thanks,
Andy
I am currently at the process where you remove the balancer bolt, and let me tell you that baby is in there, I broke my impact socket last night, I will purchase another one and try a little heat to break the locktite loose.
The Steering Assembly came out fairly easy, The instruction note to "Slide" the assembly out... The word Slide is used loosely... Mine was stuck pretty good into the passenger side bracket that mounts the assembly.
I probably have 3 hours in the project so far, probably have about 20 hours of research in the thing though. Should go back together fairly easy, I might have a total of 6-8 hours in it when I get done.
I am also taking pictures as I go, I might build a balancer R&R thread if anyone needs it.
Your thread with pics will definately help a lot of people! Goodluck!
