can't decide between two cams. HELP!
Old Sep 22, 2006 | 03:10 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default can't decide between two cams. HELP!
I'm going to get one of these two. They are both Comp. Cams..........228/230 @.050 571/573 lift 112LSA PT# 54-428-11 or this one....224/228 @.050 534/537 lift 112LSA PT# 54-418-11.......... Will the smaller cam have the lope that we all like? I figured you guys have heard about all the cams out there so what do you think. I have an M6 so I don't have to worry about a stall.
Old Sep 22, 2006 | 08:41 AM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
St. Jude Donor '08-'09-'10
I believe in the Beer Fairy
I just bought the 571/573 112.
Here is a good article about different sized cams and the power they put down.
http://www.superchevy.com/technical/.../0406phr_gen3/
Old Sep 22, 2006 | 11:27 AM
mvvette97's Avatar
mvvette97
The way they say is that if I want to keep my stock rev limit then the 228/230 would be a bit too much. Am I understanding this right?
Old Sep 22, 2006 | 02:42 PM
FKING1's Avatar
FKING1
I hae a Com Cam 224/228; .535/.538 lift & 113* separation. It has a noticable lope, wouldn't want any more. Performance is great.
FRed
Old Sep 22, 2006 | 05:37 PM
algZO6's Avatar
algZO6
why go with such a lazy lobe?
Old Sep 22, 2006 | 05:38 PM
99vettecoupe's Avatar
99vettecoupe
Either of those cams will give a nice lope. I had a 224/228 in my LS6 H/C motor and it was great. Nice lope and street manners. As you go higher you run the risk of introducing some cam surge, which can be fine depending on what you're using the car for.
Old Sep 22, 2006 | 05:57 PM
BLK02Z06's Avatar
BLK02Z06
Is there a reason for going with the smaller lobe??
Old Sep 23, 2006 | 03:14 AM
SpinMonster's Avatar
SpinMonster
Get a comp cams 224/230 XER .581/.592 lift 114+2. I actually have one for sale if you want to save some...PM. Nice lope great daily driver....easy tune.
Old Sep 23, 2006 | 03:26 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Wow... I always thought you had an A4....
Old Sep 23, 2006 | 03:38 AM
mvvette97's Avatar
mvvette97
Well i do in my vette. This cam is going in my WS6 Trans Am. I bought this not too far from you. I got it in Tonganoxie Kansas. I drove through your town.
Old Sep 23, 2006 | 06:18 AM
LowFlight's Avatar
LowFlight
St. Jude Donor '03, '17
Senior Member
Cruise-In V Veteran
The cam in my car has the perfect lope..no more no less...see signature
To can't decide between two cams. HELP!
