High pitched "whine"
Old Sep 13, 2001 | 09:26 PM
CingRed's Avatar
CingRed
Default High pitched "whine"
My 97 C5 has a high pitched whine at that is particularly noticeable at startup.It seems to be coming from behind the drivers seat and sounds like an electronic type humm that you would hear through a speaker.It changes pitch upon stepping on the brake and continues while driving.Does this sound like the fuel pump? Should I be concerned?Thanks.
Old Sep 13, 2001 | 09:31 PM
97silverbullet's Avatar
97silverbullet
Default Re: High pitched "whine" (jaympierce)
It is probably the fuel pump. '97s had loud fuel pumps. Mine was replaced under warrenty. The one they put in is louder than my original. :chevy
Just J's Avatar
Just J
Cruise-In Photographer
CI 1, 2, 7, 8, 9, 10 Veteran
St. Jude Donor '06 thru '26
Yes, it's the fuel pump. My '98 coupe did the same thing. It's nothing to be concerned about, although it sure is annoying. :(
Old Sep 13, 2001 | 09:36 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Fuel pump,there is a TSB for a quieter one...It is not a durability issue...
Old Sep 13, 2001 | 10:26 PM
CingRed's Avatar
CingRed
Default Re: High pitched "whine" (C-5 TECH)
Thanks much! Guess I'll just have to turn the radio up!
To High pitched "whine"
