Wiring a Donnelly Mirror
Old Sep 24, 2006 | 08:10 PM
RedY2K's Avatar
RedY2K
Default Wiring a Donnelly Mirror
I just bought a Magna Donnelly inside rearview mirror with auto-dimming and compass. The instructions that came with it are for running new wiring across the top of the headliner and down the A pillar to the ignition area and splicing into any wire that is only hot when the ignition is on. It seems to me that the wiring for the stock mirror ought to be usable, but I don't know how to do it. Anybody have any experience with installing a Donnelly mirror using existing wiring? BTW, the stock mirror is a maual dim type with the map lights.
Thanks.
Old Sep 24, 2006 | 08:14 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
This might help with what the stock wires are now.
http://www.c5forum.com/diy/electro_mirror.php
Old Sep 24, 2006 | 08:41 PM
RedY2K's Avatar
RedY2K
Thanks, Rich. Do you happen to know if the same wiring would be used with an electrchromic mirror with a compass?
Old Sep 24, 2006 | 10:04 PM
screw991le's Avatar
screw991le
You'll still need a ignition on source for the compass. But the rest of the mirror turns on when the lights are on.
Old Sep 24, 2006 | 10:34 PM
SJC5's Avatar
SJC5
Call this lady. She will email you the wiring code for your mirror.
Wanda VanBuskirk
Customer Service Manager
phone 800-872-2472 Ext 222
Fax 810-982-2950
www.cipausa.com
Old Sep 24, 2006 | 11:13 PM
RedY2K's Avatar
RedY2K
Sorry to be so thick-skulled, but let me make sure I'm following you. Since the maplight wiring is always hot, the wiring method described in the link you sent earlier would result in the compass being on all the time, pulling from the battery when the ignition is turned off. To avoid that, I'll still need to run wires from the mirror to an ignition on source, such as the radio. Is that correct?
Old Sep 25, 2006 | 08:18 AM
SJC5's Avatar
SJC5
Why take the chance of shorting something out???
You might be surprised that it might be plug n' play? They won't tell you because of the liability but they are very helpful.
Wanda VanBuskirk
Fax 810-982-2950
www.cipausa.com
Old Sep 25, 2006 | 11:54 AM
RedY2K's Avatar
RedY2K
Thanks, Steve. I called Wanda (actually talked to one her staff). They were very helpful and pointed out that wiring the mirror any way other than their way would void the warranty. Not worth risking damage just to be "lazy".
Old Sep 25, 2006 | 02:06 PM
SJC5's Avatar
SJC5
GaryP,
Check this link out. He is very helpfull. Saved me alot of time. Maybe he can fax you the diagrams too.
http://www.c5forum.com/cgi-bin/ultim...74.html#000003
To Wiring a Donnelly Mirror
