Codes,what to do about it??
Old Sep 24, 2006 | 09:05 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Default Codes,what to do about it??
I have two recurring codes..Both say the voltage is too high on the Intake air temp circuit...This is great but what in the world do I do about it???Thanks in advance....This is a 2000 vert by the way..
Old Sep 25, 2006 | 12:17 AM
patton's Avatar
patton
St. Jude Donor '09
get a pro. book and start testing
Old Sep 25, 2006 | 01:00 AM
sammyb's Avatar
sammyb
Daffy,
Do you have any modifications on your car, such as an upgraded intake or manifold?
If you clear the codes does the voltage code come back immediately, or under the same conditions every time?
Old Sep 25, 2006 | 01:04 AM
Daffy's Avatar
Daffy
The car is bone stock and the codes come back pretty much right away.
Old Sep 25, 2006 | 04:28 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
More than likely you need to r/r the connector that connects to the IAT. It is a pretty fairly common problem. You can check your IAT by pulling it out and measuring the resistance using a DVM. If you apply heat with a hair dryer you should see a change in the reading. The part you are looking for can be found pretty cheap at your local Chevy dealership. It will come with about 10-15 inches of wire. Just splice the connector in and clear the codes. Then drive it and see if the codes come back. More than likely they won't. Good luck with the problem and I hope it fixes it for you. Also, you could check the grounds as referenced by Bill Curlee. This guy knows his stuff.
Old Sep 25, 2006 | 08:54 AM
Daffy's Avatar
Daffy
Ok I'll give that a look,Thanks much
To Codes,what to do about it??
