'98 A4 is throwing Code P1518
Old Sep 25, 2006 | 04:33 PM
98C5RT's Avatar
98C5RT
From: Somewhere between the Red and the Rio Republic of Texas
Default '98 A4 is throwing Code P1518
I already know that it's my TAC Module Serial Data Circuit; but the question is what needs to be done to correct it or what needs to be replaced? The problem will happen intermittently and says "service traction control sys..reduced engine perf" then the check engine light comes on. The car will not rev above idle speed. If the engine is restarted it runs fine for awhile then the problem repeats.
Thanks in advance for all the great advice!
Old Sep 25, 2006 | 11:22 PM
z06inVB's Avatar
z06inVB
Cant say myself but this site has helped me trouble shoot a few codes already
http://www.gearchatter.com/viewtopic10305.php
Old Sep 26, 2006 | 09:10 AM
98C5RT's Avatar
98C5RT
Thanks Russ.
Old Sep 27, 2006 | 07:55 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Check your battery.
Old Sep 27, 2006 | 11:55 AM
timemender's Avatar
timemender
Great Site
Old Sep 27, 2006 | 12:51 PM
fixvet's Avatar
fixvet
In 4/04 I had my used '98 coupe about 2 months w/ only 20k miles on it when this happened to me sitting in a left turn lane. Needless to say, that was the longest turn of my life...at a virtual crawl. I finally got off the street and turned off the engine and waited about 3 min., then restarted....... with no bells or whistles flashing....and drove home and started researching here on the forum. I could never pin point just what caused this, but spent $200 on a new TAC module from Ken Fichtner Chevy. I waited to see if this event would happen again but it never has after 2 years and another 20k miles of all types of driving. I never did install the new module, but keep in the rear compartment of my coupe with some tools just in case. I've read about all types of probable causes, i.e. loose connections on the TB to loose connections on a ABS sensor on a wheel. I just live with it now, and try not to worry about. If it happens, it happens I guess. Weird? Yeah, I know.
To '98 A4 is throwing Code P1518
