Guys, I just bought a new V1 and the invisicord to hook it to the mirrow. I have an 00 vert and the mirrow has just the 2 reading lamps. I'm not sure from the directions where the wires plug in. The directions are about as clear as mud. Hoping someone out there has done it and remembers if its red orange blue black green or whatever. Please email me at mlewis@gbf-inc.com or call 336 317.1796 thanks, mike
The ORANGE wire that I'm using is the second one from the end.
I would suggest that you remove the mirror power connector (there's a tab at the top of the connector that you need to depress, then pull the connector off); much easier to make the connections with the connector in plain view
Suggest you shoot an email to the proprietor of invisicord. He is helpful and responsive. As the designer of the product, he will know if your set-up is compatible.
BigLew, please take a look at this thread and see if it helps. There seem to be a couple (or more) different versions of the 4 wire harness in the standard mirrors, so it has been difficult to find the differentiation factor.
If you have any questions, please contact me at sales@invisicord.com , I am sorry for the poor directions, but the installation list has been compiled from customers' installations, so it has been hard to validate or clarify in some cases.
