Headlight adjustment/Help
Old Sep 27, 2006 | 12:41 PM
BigLew's Avatar
BigLew
Default Headlight adjustment/Help
I just put new HID headlights on my car. Does anyone know of a way I can adjust them without taking them to a shop. I'm killing guys driving at night. Looking for the how to adjustment and how to know when the height is correct
Old Sep 27, 2006 | 01:57 PM
CodeName Z06's Avatar
CodeName Z06
With the lights in the open position there is a removable cap, faceing the center of the car. Remove the cap and you will see a shinny copper looking rod with a star type thread, that with adjust the up and down of the light. I cant remeber the size nor what direction to turn the rod to move it up or down. Just try different sizes until one fits and see how it moves it. Maybe someone will give the specifics, hope that helps.
Old Sep 27, 2006 | 02:24 PM
BigLew's Avatar
BigLew
Default Ok
Cool, now does anyone know the procedure for setting the correct height?? I heard someone say measure distance from ground to the center of the bulb and mark on the wall then cut the lights on and adjust?? Something like that..... how far is the car from the wall????
Old Sep 27, 2006 | 02:50 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Be easy when making adjustments as the adjusters have a tendency to break. Would squirt a little wd-40 and turn them a half turn each way to loosen them.
Sweet spot for light adjustment is 3 ft from wall. Height of beam should be around 24.5" - 25.0 ".
I would remove the black outside bezel completely to get access and lubricate.
Old Sep 28, 2006 | 07:27 AM
THRAP 42's Avatar
THRAP 42
Stern Lighting has a good "how to" here you go ... http://www.danielsternlighting.com/tech/aim/aim.html
later,
To Headlight adjustment/Help
