suspension noise
Old Sep 28, 2006 | 04:17 PM
EBM_Z06's Avatar
EBM_Z06
Default suspension noise
I’m getting a noise from the suspension when cornering hard. I only hears it during hard left hand turns and slaloms. The noise sounds like a squeak of a spring.
It is like something is in need of grease. Is this normal suspension noise ?
Anyone else hear this type of noise?
Thanks,
Alex
Old Sep 28, 2006 | 07:36 PM
EBM_Z06's Avatar
EBM_Z06
anyone ?
Old Sep 28, 2006 | 10:58 PM
Jeff Jeff's Avatar
Jeff Jeff
I had a squeak that happened quite often. Lubed the sway bar bushings and it went away. Not sure if this would work in your case, but it is something to try.
Old Sep 28, 2006 | 11:07 PM
SLPRC5's Avatar
SLPRC5
me too. I used Di-Electric grease on the bushings and sway bar bushings..no more noise. For me anyway.
Good luck
Old Sep 29, 2006 | 12:30 AM
jdmvette's Avatar
jdmvette
Night Owl for life
me 3. lubed the sway bar bushings and no more noises.
Old Sep 30, 2006 | 04:28 AM
EBM_Z06's Avatar
EBM_Z06
Thanks, I'll get the swaybar bushings greased and see if that will help. :thumb:
Alex
Old Nov 3, 2006 | 06:59 PM
Vetteoholic's Avatar
Vetteoholic
I dont know too much about suspensions but check the bushings, maybe they need to be replaced, I hope I could help a little. Hope you fix it soon.
To suspension noise
