Steve :
thanks for the reply to the previous thread. If the PCM is monitoring these KR events can you "reset" this counter prior to filling up with gas? Like pulling fuses 16 and 23 under the hood. Will pulling those fuses reset the counter to the higher spark table? If this is not the case how then can I reset this table if I am at the track and want those higher timing values.
thanks :cheers:
I donot know of any way to reset the counter other than filling the tank with more than 5 gal. Reseting the computer by removeing the power may do it but I don't know.
