Poly bushing squeek...
Old Sep 29, 2006 | 10:08 PM
Jstyle's Avatar
Jstyle
Default Poly bushing squeek...
I bought a car recently with all poly bushings. As expected it squeeks like CRAZY. It really loud and it gets old. Is there anything I can do to minimize this?
Old Sep 30, 2006 | 08:06 AM
see5's Avatar
see5
You can take them out and grease them which will last a little while or drill , tap and fit a grease fitting on each.
Sorry you asked?
Old Sep 30, 2006 | 10:52 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
spray in some P B Blaster to see if reduces it. It will seep in. That is the only simple fix. OEM bushings are bonded so they twist, they don't rotate like poly.
To Poly bushing squeek...
