clutch question (no, not sticking)
OK, I have searched through hundreds of threads and haven't really found an answer to my problem. I have a 2000 with six speed. The clutch lets out just off the floor. It starts to engage within an inch or so. It has been like this since I bought it (approx. 2500 miles ago) and has not changed. It doesn't slip. It doesn't pull sitting still in gear with the clutch in. It behaves completely normal, just feels weird being that close to the floor. And yes, the fluid has been changed numerous times and is clean. Any ideas what is causing this?
Originally Posted by Jeffs FRC
Have you driven any other M6 corvettes to compare to?
It sounds like a hydraulic issue to me. Either the slave or master, how many miles on these parts? the master is easy, I would replace it with a new one and see how it does. Be sure to bleed the system real well. If the problem still exists after that then it must be in the slave.
Originally Posted by xlr8shn
If you do not like the engagement point of the clutch, replace the clutch master cyl with an adjustable unit like RAM or McCleod.
Originally Posted by Boob
I would not get the RAM unit. I got one and am having similiar issues. I've made several attempts to contact ram to see if they can help me and I have ZERO response. Not a good company policy to completely ignore telephone calls and emails. McCleod will probably be getting a call from me soon.
