rear axle chatter
Old Sep 14, 2001 | 09:11 PM
RACER-X-C5's Avatar
RACER-X-C5
Default rear axle chatter
Hey guys, is there a remedy for the chatter coming from the rear end.
it only happens at slow take offs (thats when i hear it) .thanks
Old Sep 14, 2001 | 09:32 PM
C6~Missle's Avatar
C6~Missle
Default Re: rear axle chatter (RACER-X-C5)
Its the tranny... its normal.. some are louder than others.. Not to worry
mike
Old Sep 14, 2001 | 10:46 PM
THamilton's Avatar
THamilton
I've got the same thing. Happens most at slow speeds and tight corners, like in a parking lot.
I had my dealer tech listen to it. He is waiting for a replacement differential to show up for my car. Until then, he says I shouldn't worry, it won't blow up.
To help troubleshoot, I replaced the stock fluid with Redline. At first, the noise was better but definitely still there. After about 50 miles (two round trips to work) the noises are gone.
Other posts on the forum say this is a temporary fix. I would have the diff replaced if you're still in warranty. If not, try the Redline and see how long it lasts. I guess if you add more Limited Slip additive you can make the noises stop that way too.
Old Sep 15, 2001 | 11:25 AM
Steve-O's Avatar
Steve-O
Sounds like this would be your fix, it's a fluid change for the rear diff.
http://forums.corvetteforum.com/zero...216809#1216809
Old Sep 16, 2001 | 12:12 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Re: rear axle chatter (Steve-O)
The 6 speed cars typically make a rattle or chatter in the tranny when starting out. Since the tranny and dif are both in the back, it's difficult to tell who is the culprit. The diff fluid change is the cure only if your rear end (diff) makes a chatter or grinding or snapping noise when going around a CORNER at low speed. If that's your condition, try refilling the diff with GM synthetic plus the little bottle of conditioner. If that dosen't fix the noise, try the standard (non-synthetic) GM lube plus conditioner.
Old Sep 16, 2001 | 01:34 AM
SweetSavannah's Avatar
SweetSavannah
I've tried Redline w/ the additive and both GM synthetic w/ the additive and GM dino w/ the additive. The quietest is the GM synthetic w/ the additive.
To rear axle chatter
