clutch noise....
Old Oct 2, 2006 | 02:10 PM
killaz's Avatar
killaz
Default clutch noise....
Well, it started a month ago or so. In the morning when i first start it up, pull out of the driveway, and put it in gear, when i release the clutch i hear a schreeche metaly metal to metal noise. it only does it one time, in the morning, and it will not do it the reast of the day. it grabs like crazy, and does not slip at all. all hydrolics are zo6 equipment. any ideas?
Old Oct 2, 2006 | 05:13 PM
PolishDude's Avatar
PolishDude
not any help but my car does the exact same thing
Old Oct 2, 2006 | 08:08 PM
killaz's Avatar
killaz
lol, well if two vettes do it, it must be normal...
Old Oct 2, 2006 | 10:49 PM
killaz's Avatar
killaz
ttt
Old Oct 3, 2006 | 12:22 AM
khadiyev's Avatar
khadiyev
throw out bearing, probably.
Old Oct 3, 2006 | 10:14 PM
DALE C's Avatar
DALE C
Is there a chance the noise is comming from the rear and not the clutch? if so check for rust in the rear outer half shaft splines and tighten the nut where the spline comes thru thr rear hubs
Old Oct 4, 2006 | 12:16 AM
Tsab's Avatar
Tsab
Yep, best to try an isolate where the noise is coming from. Could be a variety of things.
To clutch noise....
