Can Oil Pan Be Removed Without Engine Removal?
Old Oct 2, 2006 | 03:07 PM
Ron Dittmer's Avatar
Ron Dittmer
Default Can Oil Pan Be Removed Without Engine Removal?
Hi All,
What exactly needs to be disassembled in order to remove the oil pan on a C5 with LS1? It's all stock with no mods.
Old Oct 2, 2006 | 03:44 PM
Black$heep's Avatar
Black$heep
Originally Posted by Ron Dittmer
Hi All,
Old Oct 2, 2006 | 04:17 PM
msghuff's Avatar
msghuff
Engine will have to be supported from above and the front cradle lowered....
Old Oct 2, 2006 | 05:04 PM
Ron Dittmer
Is that easier than completely removing the engine? If so, why? Dropping the cradle seems a lot of work too. What's involved in dropping the cradle?
Just wanting to know the pros and cons from either method.
Old Oct 2, 2006 | 05:07 PM
gonbad's Avatar
gonbad
I am in the same boat. I have a damaged pan that needs replacing. Everyone I have spoken to says I should remove the motor. They say and I agree it is not safe to be under the motor while it is supported only by an engine hoist.
Old Oct 2, 2006 | 07:39 PM
Jeff V.'s Avatar
Jeff V.
GM's own service procedures say it can be done by dropping the cradle. However, they do specify use of an engine support fixture.
I guess it really comes down to whether or not you can build or obtain said fixture, or if you'd rather undertake a LOT more effort and remove the drivetrain.
Old Oct 2, 2006 | 08:11 PM
see5's Avatar
see5
It is only about 1.5>2 hours to get it down.
Disconnect the 2 rack bolts, inner LCA bolts, motor mounts, the cradle bolts while supporting engine under the crank pulley. If you get the cradle down ~6" you can get the pan off.
Old Oct 2, 2006 | 09:21 PM
msghuff's Avatar
msghuff
Yup and a lot easier than pulling the motor!!!
Old Oct 2, 2006 | 09:26 PM
see5's Avatar
see5
Not even close!
To Can Oil Pan Be Removed Without Engine Removal?
