Service Traction Control
Old Oct 3, 2006 | 08:42 PM
Rgd2424's Avatar
Rgd2424
Default Service Traction Control
A buddy of mine owns a 2001 and the Service Traction Control and ABS light is turning on. Took it to the dealer they dont know what is causing this malfunction to occur. The codes are as following: P1571, P1689; C1277, C1288. I told him I would post this information and ask for help. Thanks in advance.
Old Oct 3, 2006 | 08:49 PM
SLPRC5's Avatar
SLPRC5
I'm thinking a bad TAC module if there is no problems with the ABS and TC. Someone else will chime in with a better answer we hope.
SC5
Old Oct 3, 2006 | 08:59 PM
Illini82's Avatar
Illini82
St. Jude Donor '07
I'm having the same problem and getting the C1214 (I think) code thrown at me. It only shows up about once a week, and disappears the next time I start the car. It was a history code when I bought the car so I think it's been an ongoing problem. I think I'm going to check all the body grounds while it's garaged this winter sometime. I really just hope the module isn't going out.
Old Oct 3, 2006 | 09:44 PM
stormrider's Avatar
stormrider
When I had this problem it took days to figure out the cause, lucky for me the car was under warranty, because the problem would disappear(i.e, the light would go off) after the car was shut down for a few hours and reappeared after about 7 miles. It turned out that the problem was in a short in the steering wheel column. Hope this helps
To Service Traction Control
