Power Antenna
Old Oct 4, 2006 | 11:20 PM
rwsasha's Avatar
rwsasha
Default Power Antenna
Hello all. Was wondering if anyone can tell me the best way to remove/replace the power antenna on a 04 vert. Any help would be greatly appreciated. Thanks again Willie
Old Oct 6, 2006 | 09:35 PM
twhanks's Avatar
twhanks
I did mine this Spring with info from the Forum. It's really easy. Remove the right, outer taillights for access to unbolt the antenna. You will access the attachment bolts and remove the antenna unit through the taillight hole. Remove the trunk trim and pull back the carpet to unhook the antenna. The only thing to be careful of is removing the grounding straps. Hold the ring terminal while removing or installing the nut. Otherwise, you can easily twist off the ground strap.
