Changing Oil-questions
Old Oct 5, 2006 | 09:35 PM
robertp's Avatar
robertp
Default Changing Oil-questions
My favorite mechanic moved to Tenn. and now I have nobody that I trust work on my vehicle. My '99 is due for it's second oil change since I've owned it and rather than bring it to somebody I don't know, I've decided to do it myself. Purchased Rino ramps and already own a floor jack and four stands. Learned enough from this forum to feel good about proper lifting technique ect. I'm using Mobil 1 10w-40, I think good for south Florida. And a Mobil one oil filter (don't know about the quality of this filter). OK so here's my question. Are there lubrication points on the chassis that I need to grease? How do I reset the oil life warning after I change the oil? Sorry for being long. Advice and comments on the oil and filter will be much appreciated.
Robert
Old Oct 5, 2006 | 09:45 PM
Vassili's Avatar
Vassili
Search the threads - but I believe you step on the gas pedal or brake pedal three times with the key in the on position...
Old Oct 5, 2006 | 10:13 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Turn the ignition on, but make sure the engine is off.
Press the "Trip" button on the DIC so that it displays "OIL LIFE" percentage.
Press and hold the "Reset" button for two seconds. "OIL LIFE REMAIN 100%" should appear on the display.
Make sure the car is somewhat level if possible. The drain plug is actually towards the front of the oil pan, so when you drive up onto the ramps, you'll miss some of the oil. I actually point my car down a slight slope and then drive it up the ramps (very slight slope!).
I'm pretty sure there are no fittings to worry about...at least I've never seen any.
Old Oct 5, 2006 | 10:30 PM
tsts's Avatar
tsts
Thats the way I do it, simple but works.
Old Nov 18, 2006 | 07:16 PM
Guro305's Avatar
Guro305
Mine just read "OIL LIFE REMAINING _ _ _%" Didn't read 100%!
Old Nov 18, 2006 | 07:34 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
It will read 100% next time you start it.
Old Nov 18, 2006 | 11:54 PM
JC in XTC5's Avatar
JC in XTC5
Even though it's Florida, you should still stick with a 30 weight oil rather than 40 since that's what's recommended for our engines, i.e. 10W-30 should be fine.
Old Nov 19, 2006 | 12:48 PM
Oldvetter's Avatar
Oldvetter
to get the last 4 ounces out, the rear has to be higher tahn the front.
Old Nov 19, 2006 | 03:01 PM
jrose7004's Avatar
jrose7004
True and I use the K & N filter.
To Changing Oil-questions
