Need help with LS1 Pulley system!
Old Oct 6, 2006 | 03:12 PM
oz98vette's Avatar
oz98vette
4th Gear
Default Need help with LS1 Pulley system!
I recently put on a new serpentine belt on my 98 LS1. Now I have two problems. The crank pulley has shifted about a quarter inch out from the engine block throwing everything out of line. Not realizing this I ran the new belt and blew the water pump. I tried tightening the bolt on the crank pulley, but it's as tight as it can get.
How do I get that crank pulley back in line?
Need help!
Old Oct 6, 2006 | 03:31 PM
timemender's Avatar
timemender
You need a new Harmonic Balancer (vibration damper). This is a known issue with the rubber spacer allowing the outer pulley ring to “walk”. Usually the pulley ends up wobbling.
Old Oct 6, 2006 | 04:11 PM
gonbad's Avatar
gonbad
I had this issue except my balancer moved in and cut through the front enging cover. Lots of damage and expensive but I did stick a new cam in there while I had it all apart.
I am helping a forum member fix this problem this weekend. We are also sticking a new cam in his car too.
To Need help with LS1 Pulley system!
