Jacking at rear crossmember?
Old Oct 6, 2006 | 06:08 PM
robertp's Avatar
robertp
Default Jacking at rear crossmember?
Tomorrow is oil change day. I have the front up on Rino ramps but I can't get my floor jack under the rear crossmember. Thought I'd drive the rear wheels up on a couple of 2x10 which will give me enough clearance for my floor jack. Question is, is it ok to place the jack under the aluminum crossmember that runs between the two rear lower control arms or is there a better place?
Robert
Old Oct 6, 2006 | 06:18 PM
John Cullen's Avatar
John Cullen
Default jack
That's what I do and I use a 2x6x12 between jack and crossmember. Before I got my kwiklift.
Be careful you don't touch the spring when jacking.
Old Oct 6, 2006 | 06:24 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I've done it carefully on the x-member w/o a wood block, but I try not to... try to use the wood to span both ribs. So long as you span both ribs the wood isn't really needed. As said above avoid the spring.
Old Oct 6, 2006 | 06:26 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I do this same method (2x6). I drive up on a couple of 2" thick planks, and then I have plenty of room to jack the car up. I have to remove the 'cup' off the jack to get that extra clearance.
Pretty obvious stuff here, but make sure you use jack stands.
Old Oct 6, 2006 | 06:31 PM
FrogmanDave's Avatar
FrogmanDave
I do it all the time. I just catch one of the ribs with my jack. That crossmember is hell for stout. Don't be skeered...it'll handle it
Dave
Old Oct 6, 2006 | 06:32 PM
robertp's Avatar
robertp
Thanks. My Vett is quite different than the vehicles I've worked on. Don't want to mess anything up. I always say if your not sure ask!
Thanks again,
Robert
Old Oct 6, 2006 | 07:03 PM
SpeedyZ's Avatar
SpeedyZ
Dave
You can chain to the aluminum cross member and bend the frame of the car back straight! Been there, done that...
Old Oct 6, 2006 | 07:21 PM
robertp's Avatar
robertp
Ouch!!!
Old Oct 6, 2006 | 08:01 PM
tiojames's Avatar
tiojames
Default jacking
There was a post a few months ago with the recommendations from GM that said not to jack from the center of either the front or rear crossmember. I have always used the center with a block of wood for the front and the back with no apparent damage.
Old Oct 6, 2006 | 08:30 PM
BanditDude's Avatar
BanditDude
I've always lifted my rear this way.
Old Oct 6, 2006 | 09:05 PM
robertp's Avatar
robertp
I think I'll cut a 2x6 to span the whole cross member between the control arms. That should disribute the weight prett well. So far nobody has seemed to had any problems jacking this way so I think I'll go for it.
Old Oct 6, 2006 | 10:16 PM
Patches's Avatar
Patches
No problem.
Old Oct 6, 2006 | 10:19 PM
Patches's Avatar
Patches
Jacking locations from most to least preferred (1-4).
Old Oct 7, 2006 | 12:28 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
One thing that hasn't been mentioned...
Remember that your transmission and parking brake only lock the rear wheels. Be sure you have the front wheels (on the ramps) chocked, or gravity will take over once you lift the rear wheels off the ground.
I wouldn't want to read on here about the car rolling backwards off the ramps and running you over.
Old Oct 7, 2006 | 01:08 AM
Tx Ray-C5's Avatar
Tx Ray-C5
Originally Posted by Patches
No problem.
I did exactly this when I installed my Magnaflow catback exhaust yesterday !! Without the ramps of course...
Old Oct 7, 2006 | 01:15 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Nice pic Patches.
Old Oct 7, 2006 | 12:12 PM
robertp's Avatar
robertp
Oil change complete. No problems thanks to all of you. Thanks for the picture Patches did mine exactly the same less the rear ramps.
To Jacking at rear crossmember?
Old Oct 8, 2006 | 08:52 AM
jimcork1's Avatar
jimcork1
I also use a low profile aluminum racing jack to get under the rear suspension. 99 Nassau Blue
Old Oct 8, 2006 | 08:53 AM
jimcork1's Avatar
jimcork1
Where were the jack stands positioned? Aluminum cross member?
thanks 99 Nassau blue
Old Oct 8, 2006 | 11:23 AM
dndrsn's Avatar
dndrsn
I made this out of Red Oak to keep it thin yet strong. With the front on ramps is just clears the rear crossmember when placed on a low profile jack. The disk on the bottom keeps it centered on the jack pad and the clips line it up on the crossmember. Handy little simple device for a lazy bastard like myself.
