Radio noise when Braking????
Old Oct 6, 2006 | 10:44 PM
Charley Hoyt's Avatar
Charley Hoyt
Default Radio noise when Braking????
I am getting static on my Bose radio whenever I have my foot on the brake pedal. Is anyone else having this problem???
Thanks for the help.
Old Oct 7, 2006 | 07:40 AM
9T3JIM's Avatar
9T3JIM
I don't have radio noise when braking but I am having a C1225 code problem. A second or two before the code sets the radio gets full of static and stays that until I reset the code.
Old Oct 7, 2006 | 08:03 AM
patton's Avatar
patton
St. Jude Donor '09
RFI have ya done any work on the car/ when did it start doing this
Old Oct 7, 2006 | 08:51 AM
9T3JIM's Avatar
9T3JIM
The only things I have done to the car are lowered on stock bolts, Baer 2pc rotors and stainless braided brake lines all done last winter. The problem started this July. I am going to switch out the brake lines and put the stock ones back on.
Old Oct 7, 2006 | 10:22 AM
DPG's Avatar
DPG
St. Jude Donor '06
sounds like a grounding issue. Seems that you have it narrowed down to the SS brake lines
Old Oct 8, 2006 | 03:26 PM
Charley Hoyt
That's what my issue was. It turns out that if you remove the rear right (outside) tail light...there is a ground that is shared between the antenna and the brake lights. That is where my issue was.
To Radio noise when Braking????
