High Oil Pressure...
Old Oct 7, 2006 | 10:10 AM
Corps 'Vette's Avatar
Corps 'Vette
Default High Oil Pressure...
I got in my vette yesterday and all of a sudden the oil pressure is hanging out in the high 70's at idle. Driving home I almost pushed it into three digits. I turned the car off and then on again to see if it was a glitch. Also, the DIC and the gauge had the same reading.
Anyone know what causes this?
Old Oct 7, 2006 | 10:15 AM
quimbo's Avatar
quimbo
Sounds like a bad sending unit very common i think its located under the intake manifold
QUIMBO SEEYAAAH
Old Oct 7, 2006 | 03:06 PM
Ta-taaa's Avatar
Ta-taaa
Yup,
It's under the intake. I need to replace mine too! Mine pegs out!
Old Oct 7, 2006 | 05:26 PM
W Muller's Avatar
W Muller
There are a lot of posts on this common problem. The only ones who seem to have the problem reoccur are the ones who replace the bad sender with an AC Delco.
Old Oct 7, 2006 | 06:52 PM
cruisemon's Avatar
cruisemon
OEM sender, aluminum housing, leaking. Replace with Standard brand (I think - do a search on oil pressure sender to be sure). It's under the intake manifold. There is a vacuum line that controls your AC doors. Put an extension on the line to make it easier to hook up after you get the manifold back in place. You do NOT want to use the genuine GM part made in Mexico with the aluminum housing. Use aftermarket with a brass housing for longer service life.
Charlie
Old Oct 12, 2006 | 10:46 AM
Bajapit's Avatar
Bajapit
I drove Nancys 99 Coupe today and Noitced the Oil pressure Pegged and the Digital gage reading 126 , Restarted, still present.
Is it hard to change the sender?
Old Oct 12, 2006 | 11:54 AM
David426's Avatar
David426
This is the biggest known problem on the C5.. Don't get another from the dealership or you will be replacing it again
Old Oct 12, 2006 | 12:53 PM
rws.1's Avatar
rws.1
Check out this post by Vectorz
http://forums.corvetteforum.com/show...ressure+sensor
Old Oct 12, 2006 | 05:17 PM
Bajapit's Avatar
Bajapit
Wow That is out of this world. Thanks. Even in color. Thank's Victorz and RWS.1 This is Great.
Where can one get the Fuel Line Remover Tool? Is it available online?
Old Oct 12, 2006 | 08:03 PM
RedC5's Avatar
RedC5
Anyone feel there will be a recall on this someday?
Old Oct 12, 2006 | 08:48 PM
spider94r's Avatar
spider94r
I doubt it, because it's not a safety issue, just an annoyance.
Kevin
Old Oct 12, 2006 | 09:03 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I got one from the dealer, if failed, second one is working great; try Autozone for the sender
Old Oct 12, 2006 | 09:53 PM
rubyjames's Avatar
rubyjames
Old Oct 13, 2006 | 02:44 PM
Bajapit's Avatar
Bajapit
Will this tool work to release the fuel line on the 99 disconnect?
http://www.amazon.com/exec/obidos/AS...6-20/ref=nosim
Old Oct 13, 2006 | 02:55 PM
cruisemon's Avatar
cruisemon
Yowzah! We have a winner. Thanks for the link and the info!
Charlie
Old Oct 14, 2006 | 04:50 PM
B-rent's Avatar
B-rent
Lol you think 70 is bad? mine reads 130psi talked to the dealer and got a new sensor at $35 from advance auto, just havent put it in yet
Old Oct 14, 2006 | 06:14 PM
Patches's Avatar
Patches
With my ported oil pump, I'd be worried if it didn't hit 70 psi. Stock pump runs a wee bit lower.
Here's the fuel line removal tool I got at NAPA. Most any parts store will carry one version of this or another.
To High Oil Pressure...
