C6 to C5 Wheel Question
Old Oct 7, 2006 | 02:31 PM
FLL-Mike's Avatar
FLL-Mike
Default C6 to C5 Wheel Question
Will the C6 wheels and/or C6 Z06 Wheels fit the C5 without making any mods?
Old Oct 7, 2006 | 03:04 PM
louzon's Avatar
louzon
I don't know about the C6 Z06 wheels but the regular C6 will fix.
I do have 3/16ths spacers on the rears to keep them from rubbing the wheel wells on big bumps.
Old Oct 7, 2006 | 09:31 PM
jdmvette's Avatar
jdmvette
Night Owl for life
c6 replicas that are made for c5 offsets will fit w/o problems. oem c6s will not fit properly without spacers as mentioned above.
Old Oct 9, 2006 | 10:36 AM
FLL-Mike's Avatar
FLL-Mike
A few Q's please...cause I dont know what spacers are.
Where can I purchase the spacers?
How do you apply them to the well?
Where do you place them?
Also, just so that Im clear, they are 18s on the front and 19s on the rear.
Thanks so much, Mike
Old Oct 9, 2006 | 12:08 PM
MeekRN's Avatar
MeekRN
Default yes they fit
i am using stock C6 polished wheels and they fit perfectly, no problem with abs or traction control either since the stagger is the same.
Old Oct 9, 2006 | 02:44 PM
louzon's Avatar
louzon
Default Hope this helps.
Same wheel sizes as mine.
I got my spacers from Corvette Forum member JC-5 I don't know if he has any left?
The spacers fit between the wheel and the hub.
You need to watch how thick you go with stock lugs as you need to have enough thread left to torque them to 100 f/lbs without stripping them.
I used 3/16 ths (.187) of an inch with no problems.
Check this site to see what they look like http://www.ezaccessory.com/Wheel_Spacers_s/27.htm
I believe some of the forum vendors sell them as well.
But I don't know their prices.
Old Oct 9, 2006 | 02:47 PM
louzon's Avatar
louzon
Default ????
Are you sure they do not rub the sides of the rear wheel wells when you compress the supension? Mine is a daily driver so I do hit some good size bumps once in a while and mine would rub the side of the tire on the wheel well a little.
Old Oct 9, 2006 | 09:52 PM
RickC5's Avatar
RickC5
Stock C6 wheels will NOT fit without spacers in the rear.
In my old C5 I had to run spacers in the rear, and even then they still looked a little sunken in.
Now C6 Z06 wheels in 18x9.5 and 19x11 fit just fine on C5's with no need for spacers.
I suggest contacting Bob at House of Wheels for your C6 wheel needs
Old Oct 10, 2006 | 02:10 PM
crvtble's Avatar
crvtble
Don't do the spacers...the "adapters" are the way to go. Billet aluminum 1" thick. they bolt to your existing lugs then provide 5 studs to put your wheel on. Plus the 1" increase makes the wheel fill in the fender opening for a better look. Ebay has a couple of pages of places that sell the adapters..from cheap to ...$$$$.
To C6 to C5 Wheel Question
