Opening Headlight motor gearbox
Old Oct 7, 2006 | 09:22 PM
Trudge's Avatar
Trudge
6th Gear
Default Opening Headlight motor gearbox
I'm following instructions from another post covering the replacement of the nylon gears with brass replacements.
I get to the part about opening the gearbox and I find that my Headlight Motor Gearbox does not have the cover with the 3 screws. It looks to me that the gearbox is permanently sealed.
Any suggestions or a link to a post covering this problem.
Jerry
Birmingham, AL
2001 Millenium Yellow C5 Coup
Old Oct 7, 2006 | 09:44 PM
timemender's Avatar
timemender
The gear housing on the later years must be cut open and then put back together with epoxy. Do a search, as there is a supporting vendor that sells the brass replacement gears with an epoxy kit included.
Old Oct 7, 2006 | 11:02 PM
jdmvette's Avatar
jdmvette
Night Owl for life
the epoxy won't hold for long. i used alternative methods to keep the lids on my motors.
Old Oct 7, 2006 | 11:21 PM
tsts's Avatar
tsts
Try this link, he explains about the epoxy and has added a piece to hold it together even if the new epoxy fails.
http://www.rodneydickman.com/n113.html
Old Oct 9, 2006 | 07:37 AM
jmliles's Avatar
jmliles
I replaced my gears about a year ago before anyone brought up the issue of the epoxy not holding... make sure you install the brace or take other measures to reinforce the epoxy because it definitely *will* fall off
Old Oct 9, 2006 | 11:50 PM
JC in XTC5's Avatar
JC in XTC5
Just did mine last month. As per the instructions, you'll need to pry the cover off by breaking the glued seal. Once you get a small screwdriver into the seam and get it to start spreading it will come apart fairly easily.
And as per the instructions, the cover will be clamped with a metal brace after epoxying it to prevent it from opening after the repair.
To Opening Headlight motor gearbox
