For the redesigned FFS fuel system introduced in mid model year 2003, there is no service interval for fuel filter replacement according to the 2003 GM Service Manual. The fuel filter is part of the left fuel sender assembly inside the left fuel tank. The left fuel sender assembly also includes a fuel level sensor, the fuel pump and reservoir assembly, the fuel pump strainer and the primary fuel pressure regulator. If necessary, the left fuel sender assembly is changed out as a complete unit according to what I've read in the GM Service Manual.
i have read that and don't but it. serioulsy what is it doing different than any other fuel filter that makes it last forever? it is just like the OEM plugs that last 100,000 miles, doesn't happen.
reason being is that i just put a TNT kit on top of my H/C and the last thing i need to worry about is a clogged fuel filter. granted my car only has 14K on it but i am in the habbit of changing out my fuel filter every 15K.
When the fuel filter stops up, the fuel pressure increases, and it usually takes the fuel pump with it.
Since you have to drop the fuel tanks to change it, you could just wait until the whole assembly needs replacing. Unfortunately, you could end up stranded somewhere if you wait until total failure.
yes, to change it you have to buy the whole bucket assembly and drop the tank.. Major $$$$. Probably cheaper in the long run to switch to the ECS fuel system with an external pump and filter....
No, the ECS fuel system still uses your stock pump and stock filter. So this could still be an issue. The ECS system does include another filter, however, I would still be concerned with the in-tank filter clogging up first (especially since it will see fuel first).
You may run the risk of emissions inspectors finding the car out of compliance, depending on how hard they will be looking in the future.
The modification was made as a running change in mid-model-year 2003and all subsequent Corvettes. It was mandated by the EEEEE-PEEEE-YAAAY:a downgraded fuel injection system and the placing of the fuel filter INSIDE the fuel tanks. Earlier cars have the fuel filter outside, reasonably accessible for those of us who have had occasion to change the fuel filter in our cars from time-to-time.
This is a maintenance cost that should be considered when purchasing a mid-model year 2003 and later car. It will happen, especially if the owner isn't picky about the gasoline that goes in the car's tank.
It was enough to turn me off of purchasing a C5 manufactured after than the changeover.
Never say never. The ECS fuel pump by default will run off your factory fuel pump relay. You could easily wire it in to your fuse panel in a way that it will run and your factory pump won't. Only problem is you're losing a lot of fuel supply that way. Also, just my personal opinion, but you lose an option available to you that makes the ECS kit streetable to even your grandmother... making the secondary pump run only at WOT or under bost.
The first time I have to go into the driver side tank I am going to remove the filter assembly from inside and provision for an external fuel filter. But until that day comes I am just going to keep a keen eye on fuel pressure.
I have a model year 2004 with 77K miles on it. I will not be happy when my fuel filter needs changing. What kind of job is it to do what you are talking about ?????
And is there any way to tell if your filter is nearing the end of its usefullness.....
DH
My service manual doesn't cover the 2003.5+ FFS systems (the one you and I have) but my understanding is that you need to drop the rear cradle/suspension in order to drop the gas tank.
We are doubly hosed on this one... not only is the filter inside the tank but you have to drop the tank to get the filter out because the sender bolts in to the tank from the top
I am not sure if there's a better way, but I usually know it's time to change the filter just by keeping an eye on fuel pressure.
I've looked at mine, looks like the tranny and all would have to be dropped....
wouldn't your fuel pressure drop if your filter gets clogged (assuming you are using a FP gauge at the end of the rail)? after about another 10K hopefully we will have a solution if not i will find a way to remove the internal filter and put on an external. Howie, i would after 77K i would definatly look into changing your filter.
See above -- this was my suggestion as well (checking of the filter is failing by observing fuel pressure).
I would not recommend just changing the filter just because the car has 77K miles on it. I would check fuel pressure over a broad range of operating conditions before doing so.
so by the fuel filter being clogged, the fuel pressure would drop at the rail? what should the pressure be?
