How Do I Check Codes On 2005 Zo6?
Old Oct 8, 2006 | 09:59 AM
RODMAN1966's Avatar
RODMAN1966
Default How Do I Check Codes On 2005 Zo6?
What Buttons Do I Push To Check For Codes 2006 ZO6 SORRY?
Old Oct 8, 2006 | 10:09 AM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
I posted this a few weeks ago but 'mod' didn't put a sticky on it.
http://forums.corvetteforum.com/show....php?t=1514518
Old Oct 8, 2006 | 10:41 AM
proracr's Avatar
proracr
The folks in the C6 Tech section might be able to help you. Is there a 2005 Z06?
Old Oct 8, 2006 | 11:36 AM
ZO6vettepilot's Avatar
ZO6vettepilot
Originally Posted by RODMAN1966
What Buttons Do I Push To Check For Codes?
You can't check codes on a 2005 Z06, there was no 2005 Z06. Can you be more accurate on the year and/or model you need assistance on?
Old Oct 8, 2006 | 02:42 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
I assumed he meant C5 Z06.
Old Oct 8, 2006 | 03:04 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
There is already a C5 tech tip that covers how to pull up codes:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Oct 8, 2006 | 03:29 PM
see5's Avatar
see5
My guess is it is in the owner's manual.
Old Oct 8, 2006 | 03:32 PM
RODMAN1966's Avatar
RODMAN1966
It's not in the owners manual, 2006 ZO6.
DOES ANYONE REALY KNOW?
Old Oct 8, 2006 | 03:45 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Post this question in C6 General or the Tech section, but basically you need a scanner because the codes cannot be checked like they can be on a C5.
Old Oct 8, 2006 | 03:46 PM
SLPRC5's Avatar
SLPRC5
He said a 2006 ZO6. I have been told there is no way to do the code check on the C6 Corvettes.
Old Oct 8, 2006 | 04:56 PM
debmwb's Avatar
debmwb
Since you're in the C5 forum you may not find the correct answer. You should ask the question over in the C6 forum to be sure.
Old Oct 8, 2006 | 08:03 PM
boosted_z06's Avatar
boosted_z06
The C6 does not show or allow error codes to be erased via the DIC as the C5 does.
If you have On-Star GM could tell you if codes are present else you need to buy a code reader that works with the new EPA "CAN" OBD protocol or a full scanner that you can use via a P/C or laptop
Old Oct 10, 2006 | 12:59 AM
RODMAN1966's Avatar
RODMAN1966
Thank You...rod
To How Do I Check Codes On 2005 Zo6?
