Wiring Harness from Ignition
Old Oct 9, 2006 | 11:07 AM
RedY2K's Avatar
RedY2K
Default Wiring Harness from Ignition
This weekend I pulled the console to switch radios. I noticed a two-wire harness from the ignition key area that wasn't connected to anything. I don't know if I knocked it loose or if it was loose before. Any ideas on what it might be?
Thanks.
Old Oct 9, 2006 | 11:46 PM
JC in XTC5's Avatar
JC in XTC5
If you don't have the Auto-HVAC, then that could be the internal temp sensor wiring that you wouldn't be using.
Old Oct 10, 2006 | 09:29 AM
RedY2K's Avatar
RedY2K
Thanks, JC. I do have the climate control HVAC and it seems to be working fine. I'm beginning to think the previous owner of the vehicle had an aftermarket something-or-other connected to the harness.
To Wiring Harness from Ignition
