Help Driver Side Power Window Failure
Old Sep 16, 2001 | 12:36 PM
Sgerh's Avatar
Sgerh
Default Help Driver Side Power Window Failure
Any comments or suggestions on the information below would be greatly appreciaited!!!
My driver side window is locked in the up position and the electronic button won't budge it. Now the driver side console is working (mirrors, passenger window and memory options) with the exception of the driver side window. I believe the driver side power window has its on fuse. I believe it is minifuse #34 for the power feed door left. Please confirm if this is correct. However, I am not exactly sure where the fuse box for the interior items is located. I have not gone out to the car to check yet, and the corvette manual only specifies the location of the fuse box for the engine compartment items.
Any help on the fuse # and location of the fuse box for the driver side window is appreciated.
Scott
Old Sep 16, 2001 | 01:13 PM
Flintstone's Avatar
Flintstone
Default Re: Help Driver Side Power Window Failure (Sgerh)
Does the instrument panel dim when you press the window switch, i.e. does it sound or look like the window motor is 'trying' to lower the window?
If so, while pressing the window switch, smack the door panel with the palm of your hand just to the upper left of the speaker. If your motor contacts are 'sticking' this will usually work.
Temporary fix though - it'll happen again, so take it to the dealer.
F :yesnod:
Old May 26, 2019 | 11:22 AM
Akaiha's Avatar
Akaiha
8th Gear
Hello family my window1992 chevy wont come all the way up it went half way and just stoped..Could I check the fuses and which one?. The other indown works perfectly had moter regualtor fixed last year. Rain storm coming for seven day please help Dansel in detress
Old May 26, 2019 | 11:23 AM
Akaiha's Avatar
Akaiha
8th Gear
To Help Driver Side Power Window Failure
