Driver's seat memory problem
Old Oct 10, 2006 | 10:55 PM
Bob Chapman's Avatar
Bob Chapman
Default Driver's seat memory problem
My drivers's seat memory is inconsistent. Sometimes the seat moves forward to the set position but usually it only goes part way. Pressing the memory control on the door will get the seat to move forward in very small increments until it gets to where it should be. All the electrical connections have been checked including grounds and a new seat control module has been installed - still not working right. Any suggestions would be appreciated.
Old Oct 11, 2006 | 12:34 AM
blue99frc's Avatar
blue99frc
Sounds like there has to be a bad connection somewhere. Did you check the plug below the drivers A pillar because there is a lot of movement there (door hinge point).
Old Oct 11, 2006 | 01:28 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Common problem. Mine got better after I replaced the battery. YMMV.
To Driver's seat memory problem
