CD Changer
Old Oct 11, 2006 | 05:21 PM
whiplash 1's Avatar
whiplash 1
Default CD Changer
I have a 1997 corvette and purchased a factory cd changer for it. It has a 3-way female connector and a 4-way male connector on the cd changer harness that plugs in to the factory body harness. I found the 4-way male but cannot find 3-way female. HELP!!!!!!! I don't want to tear out the whole wiring harness looking for this.
Old Oct 11, 2006 | 05:54 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is in the footpanel on the passanger side. One is tucked in the kick panel.
Old Oct 11, 2006 | 07:36 PM
whiplash 1's Avatar
whiplash 1
I checked the kick panel and don't see nothing there unless it is taped up in the harness where i can't see it.
Old Oct 11, 2006 | 09:00 PM
djengr's Avatar
djengr
This is from my 2001. I took picture when I mounted the CD in the back. Mine was taped onto another set of wires. It took a bit of looking but I found it. Had to pull carpet back a little.
Good luck
Old Oct 11, 2006 | 09:53 PM
whiplash 1's Avatar
whiplash 1
I know this is asking a lot? But do you know where the set of wires were located that it was taped to? Kick Panel, Floor. Etc. My luck it will be the last set I unwrap. I have heard that some early models did not have this plug??
Old Oct 13, 2006 | 09:09 PM
djengr's Avatar
djengr
I am afraid the 97 did not come prewired to the footwell like later models. I think chevy started pre wiring to the footwell in 2000 or 01. You will need to get to the back of the stock radio to do the wire job. I have not seen any post on that procedure, but you will need to remove center console and the panel around the radio to get to it at least. good luck.
Old Oct 20, 2006 | 11:32 PM
whiplash 1's Avatar
whiplash 1
I think you are right because I can't find any. If I can pick up the dark green wire from the radio without taking the radio out I think I can make it work.
To CD Changer
