Ah....Racetronix Install Frustrations..
Old Oct 12, 2006 | 12:59 AM
Riggs's Avatar
Riggs
Default Ah....Racetronix Install Frustrations..
Well,
I got the car back together, and noticed my fuel gauge is showing me on empty...I have 7 gallons of gas I just put back in the tank, so I know that's incorrect.
While working on the fuel pump assembly, I was confused on how to connect the fuel level sending unit to the Ractronix 4-Prong OEM Style Black Connector...
The Power and Ground wire from the Fuel Pump came pre-wired with the Racetronix 4-Prong Black Connector, with two of the 4 holes open for the Fuel Level Sending Unit to plug into, I assume...
Getting the Fuel Level Sending Unit Wires out of the factory 4-Prong Connector was hard enough, but I can't figure out how to get them into the Racetronix 4-Prong Connector.
I believe I have bent them two badly and will need to have those wires replaced.
Any suggestions on how to do this?
Old Oct 12, 2006 | 01:24 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
Originally Posted by Riggs
Well,
Contact support@racetronix.com
Old Oct 12, 2006 | 08:25 AM
Riggs's Avatar
Riggs
Originally Posted by Racetronix
Hi,
I appreciate the email, but if you are Racetronix, can you answer this question for everyone else to see...
This may be an issue others will experience and a public reply is in order...
Old Oct 12, 2006 | 11:06 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Check out http://www.cajundude.com. He's got a real good set of install instructions. I did not have any problems getting the fuel sender wires out of the connector using a paperclip. Then they clicked right into the Racetronix connector.
Old Oct 12, 2006 | 11:07 AM
Boob's Avatar
Boob
Funny thing: I have those wires from my Racetronix install. It was extremely easy from what I remember. I did get hung up on that part for just a little while.
I'd be happy to "pay it forward" if you'd like to pay for shipping. I'll need to double check but I'm quite sure I have them.
Old Oct 12, 2006 | 11:26 AM
Riggs's Avatar
Riggs
My car is going on the dyno tomorrow, which is the reason I'm frustrated....
Is there any kind of special too one should use, as I need to figure out where to buy more connectors....
I have torn those up badly at this point..
Old Oct 12, 2006 | 11:28 AM
Riggs's Avatar
Riggs
Racetronix should link this on their website, as no instructions came in the package...
Old Oct 12, 2006 | 01:28 PM
Riggs's Avatar
Riggs
How much is the fuel level sensor?
I broke one of the soldered wires, and there is no point in trying to fix it, as the new solder will not stick to the board.
Old Oct 12, 2006 | 08:09 PM
Riggs's Avatar
Riggs
bump.
Old Oct 12, 2006 | 08:57 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I think it is around $80 from dealer. Check with Fichtner or Beans, they will have the best price.
I think I took pics of that when I replaced mine but apparently did not do a write up yet.
Old Oct 12, 2006 | 10:13 PM
Riggs's Avatar
Riggs
can you email them to chrisariggs@hotmail.com
Old Oct 12, 2006 | 10:15 PM
Cajundude's Avatar
Cajundude
Lemme see if I can find them.
Old Oct 12, 2006 | 10:21 PM
Riggs's Avatar
Riggs
Due to the fact there is no way this piece is going to be fixed by tomorrow, I hope it wont interfere with my dyno tuning session tomorrow.
The car doesn't reduce power when the low fuel level lights flashes does it? It doesn't go into a limp mode, etc?
Just want to make sure...
Old Oct 12, 2006 | 10:39 PM
Cajundude's Avatar
Cajundude
No, you can ride around as long as you want with the fuel gauge not working, just don't run out.
I looked on my desktop, my laptop, my camera, and my wife's camera for the pics. I can't find them or my notes so I guess I can't help you with those until I do it again.
It really is not hard. Just look at the pics in the Racetronix install. The replacement piece will even come with a new float (mine did). The replacement piece is the whole board, plastic and all, you simply plug it in.
Old Oct 12, 2006 | 10:43 PM
Riggs's Avatar
Riggs
Good, I ordered part #10333749 from GMPartsDirect.com
SUBTOTAL:
$67.81
PROCESSING & HANDLING TOTAL:
$14.92
TAXES:
$0.00
ORDER TOTAL:
$ 82.73
Old Oct 12, 2006 | 10:44 PM
Cajundude's Avatar
Cajundude
To Ah....Racetronix Install Frustrations..
