DIC reads low oil level
Old Sep 16, 2001 | 08:09 PM
AZ C-5's Avatar
AZ C-5
Default DIC reads low oil level
When first starting in the morning I got a "Low Oil Level" readout. I checked the oil and it was right on the mark. I hit the "reset" button and it was gone, only to come back every so often for two more days of driving. The third day after filling with fuel, it didn't come back and hasn't since. Anyone else have a similar problem? Not to worry???? :flag
Old Sep 16, 2001 | 08:12 PM
carpe dm's Avatar
carpe dm
Default Re: DIC reads low oil level (AZ C-5)
It takes awhile to reset. I have heard of this happening; if it comes back, have them check it out. :yesnod:
Old Sep 17, 2001 | 01:48 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
If your getting a low oil level and it returns.... I would add 1/2 quart..see if it returns
give it a few hours to settle..
Old Sep 17, 2001 | 11:42 AM
johnnybg's Avatar
johnnybg
I had the same problem coming home yesterday from the Mid America Funfest.
My car was parked at a slightly downhill grade overnight. I was down about a half of quart. Added that, but it kept on coming back every 13 miles or so on the ride home. Shut the car off several times to along the way(food, reststops, etc.). Will see if having it parked over night in my garage will solve as some one else suguested. WIll keep you posted. :yesnod:
Old Sep 17, 2001 | 12:02 PM
Evil-Twin's Avatar
Evil-Twin
Default Re: DIC reads low oil level (johnnybg)
Had the same problem...Let it sit over night and all was well
Old Sep 17, 2001 | 12:58 PM
All Are Red's Avatar
All Are Red
I had to have the sensor replaced. It was an easy fix for the dealer. I would believe you dipstick over your DIC
Old Sep 17, 2001 | 02:28 PM
AZ C-5's Avatar
AZ C-5
Thanks for your input....It had been parked on a slight incline...facing down hill. I was surprised it took so long to reset itself...(several hundred miles) :confused:
Old Sep 17, 2001 | 04:19 PM
CDHough's Avatar
CDHough
Cruise-In II Veteran
I have had it happen. It usually is ok but sometimes it reads low when it is not.
Old Sep 18, 2001 | 09:28 PM
johnnybg's Avatar
johnnybg
MIne went away also after letting the car cool down and being parked on a level surface overnight. Drove it today about 300 miles and no problem. :yesnod:
To DIC reads low oil level
