Replacing A/C belt help.
Old Oct 12, 2006 | 01:07 PM
my6thvette's Avatar
my6thvette
Default Replacing A/C belt help.
Replacing the serpentine is a piece of cake but I am having trouble with the A/C belt. Does anyone have any suggestions for getting the A/C belt on, without growing an extra hand?
Old Oct 12, 2006 | 01:20 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
hmmm...I did it at the same time as serpentine belt....it was pretty easy since it has the tensioner also....maybe my hands are just smaller
Old Oct 12, 2006 | 01:25 PM
Zumin's Avatar
Zumin
I've heard that it can be tricky if you have an auto, apparently there's some extra lines in the way on autos, believe someone suggested taking a clip off that's in the way and threading the socket in between the lines if that's the problem you are running into.
Old Oct 12, 2006 | 01:32 PM
SLPRC5's Avatar
SLPRC5
I got mine off and on with no problem. With large hands
Old Oct 12, 2006 | 01:42 PM
rws.1's Avatar
rws.1
follow this link and read my post (4th down)
It has additional link to two good how to's
http://forums.corvetteforum.com/show...ighlight=belts
Old Oct 12, 2006 | 01:50 PM
my6thvette's Avatar
my6thvette
Yes, it is an automatic and the extra lines are a lot of the problem. Clip is off and lines can be spread to reach the tensioner but it is still difficult to thread the belt into the correct position while compressing the tensioner.
Old Oct 12, 2006 | 08:46 PM
DngrZne's Avatar
DngrZne
When I did mine I had trouble with it because it seemed as though the belt was too small. Seems the trick is when the tensioner stops moving, that is the time to really lay into it, and it will move a bit farther and the belt will slip on.
To Replacing A/C belt help.
