Not a really good way that I know of, unless you have a scanner or it throws some codes.
You can also check the condition of the spark plugs. The cylinder that's misfiring will most likely look different (black in most cases) than the rest. Move the coil/injector/or wire and see if the dirty plug follows the component move.
