I need Engine Builders Help..
Old Sep 17, 2001 | 12:31 PM
vmoore's Avatar
vmoore
Default I need Engine Builders Help..
I tried to ask this question, but it seem I was talking to only two people and I could not get a vendor to get in on the discussion.. I want to know what is the maximum compression I could run on a LS1 346 cu with a cam 221/221 558/558 lsa 112..? I have heard people going up to 11:5.1, but I was wondering if I could run 11:7.1 and still run 93 octane. I have no problem sending my computer back to Ed Wright for adjusting. I just want to know what kind of benefits if any or what are the negatives of doing this?
Old Sep 17, 2001 | 06:04 PM
vmoore's Avatar
vmoore
Default Re: I need Engine Builders Help.. (vmoore)
ttt
Old Sep 17, 2001 | 08:01 PM
MitchAlsup's Avatar
MitchAlsup
If you assume that power goes up linearly with compression, you are talking less than 2% change (for the better) in HP.
But HP does not go up linearly with compression. The compression stroke is not an iso-thermal event, it is an adiabatic event (pressure and temperature change simultaneously). Likewise the expansion (power) stroke is an adiabatic event.
Given reasonable numbers for air and vaporized gasoline and compression ratios, you should be able to achieve between 60% and 70% of the gains of the previsously assumed linear relationship. Now we are talking about 1.5% difference in HP between 11.5:1 and 11.7:1.
Is it worth it to step over the line and require "special blended gasoline"?
Old Sep 17, 2001 | 08:11 PM
TLewis4095's Avatar
TLewis4095
Default Re: I need Engine Builders Help.. (MitchAlsup)
Great reply Mitch, the mods available without crossing the compression ratio barrier seem to be more than enough for those seeking another 10th off their time slips. :chevy
vmoore's Avatar
vmoore
Then it sounds like I should go no higher than 11.5:1. I might take another persons advice and go 11.3:1 to be safe.. Thanks Mitch
Old Sep 17, 2001 | 08:40 PM
Chris@SD's Avatar
Chris@SD
That hurts! I coulda sworn I was a vendor... ;)
Old Sep 18, 2001 | 02:16 AM
vmoore's Avatar
vmoore
Default Re: I need Engine Builders Help.. (2FST4U)
Sorry about that... It seemed like you were trying to interest me in a solid roller cam. I asked you about pricing, but I never rec'd a email from you..
Old Sep 18, 2001 | 02:26 AM
vmoore's Avatar
vmoore
Do you think my cam is big enough to test the limits?221/221 558/558 lsa 112?
To I need Engine Builders Help..
