160 Thermo question
Old Oct 18, 2006 | 08:50 AM
kylryn's Avatar
kylryn
Default 160 Thermo question
I installed the 160' Thermo in and everythign looks and runs great when Im driving. When I sit idol for a long period of time the temp gets up to 230. Is this normal? Shouldnt the fans kick on and start cooling it down before it gets that hot or is that not too hot?
thanks.
Old Oct 18, 2006 | 09:38 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
The 160 degree t-stat only opens sooner. Your fans are still set to come on at 226 degrees. So the t-stat opens sooner now, allowing water to flow through the system at a lower temp and when you are moving there is enough airflow across the radiator to cool the engine down lower than with the stock t-stat but when not moving it just heats up until the fans come on at 226 (stock first fan temp).
You need to get your fans programmed to come on earlier or get a Vinci fan controller.
Old Oct 18, 2006 | 10:51 AM
FRCTony's Avatar
FRCTony
I have found that changing the fan settings works, no need to change thermostat.
FYI, I never had issues with cruisng temps, only stop and go with A/C on.
Old Oct 18, 2006 | 01:37 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
I turn on the ac to lower the water temp. Here in south FL. at a light my water temp goes to 235 with ac off. When the ac is turned on the fans come on and drop the temp to 210.
Old Oct 18, 2006 | 05:47 PM
azzhauler's Avatar
azzhauler
The fans need to be on sooner. Turning them on before the tstat opens though is a waste, and depending on where you set them could be rather bad for them. With the stock tstat maintaining 194 on the highway, if you program them to cut on at 170, they will run until you cut the car off because the temp will never fall below ~194. It would probably cool the radiator lower than 194, but once the coolant in the engine heats enough to open the tstat it will cycle the hot water out and new water in, which would only stay cooler for a short time. Also, I'm not sure if it's true on vettes like it is on fbodies, but at highway speeds the fans are actually a hinderance as the moving air moves more/faster than the fans can pull it.
Old Oct 18, 2006 | 06:10 PM
FRCTony's Avatar
FRCTony
The fans normally do not operate above 35mph.
Old Oct 18, 2006 | 06:25 PM
kylryn's Avatar
kylryn
Thanks Guys, So I shouldnt be conserned?
Old Oct 18, 2006 | 06:43 PM
Casem1's Avatar
Casem1
i bought a 172 deg stat and tested it on the stovetop with water and a meat thermometer. It opened just above 190 deg. I am pretty sure the thermometer was fairly accurate because the water began to boil between 205 and 210 deg according to it (obviously 212 being the ideal). I just kept the stock one installed. I guess the best thing to do is test them both at the same time.
Old Oct 18, 2006 | 07:12 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
No, that's normal if your fan setpoints haven't been altered.
The lower temp thermostat doesn't do anything to control how hot get your car gets, it only controls how cold it can run.
Lower temp stats are normally installed to allow lowering the fan turn-on points, without having the fans run constantly, which is what inevitably happens if you lower the fan setpoints too much with a stock Tstat.
To 160 Thermo question
