Carroll Supercharger !!!!!
Old Sep 17, 2001 | 07:09 PM
viper8789's Avatar
viper8789
Default Carroll Supercharger !!!!!
Just put a Carroll Supercharger on my car....1999 FRC.........since they don't seem to want to help their customers after spending 8000.00 maybe someone else can.........I left several messages for Mr Carroll himself and have not received a reply yet :mad :mad :mad The car has some detonation on the high end.....does anyone know what the highest octane I can run in the car ? Maybe this would help ? the air/fuel mixture seems fine on the laptop. Hope to get it to the track this weekend.
Old Sep 17, 2001 | 07:16 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Carroll Supercharger !!!!! (viper8789)
I don't know the most intricate specifications, but one of the reasons I stayed away from Carrol Superchargers is the fact that they don't use an intercooler. If you are blowing hot air down your intake it may be heating the motor and causing detonation. I do know for a fact that when your motor gets too hot it will detonate. The LS1/6 being all aluminum dissapates alot of heat, that is why it likes the wet shot of N02. I will say that I think the Carrol Supercharger looks the best installed. They should definetly be call you back, if for any reason just customer service. :cool:
Old Sep 17, 2001 | 07:17 PM
Peach's Avatar
Peach
Orlando Events Coordinator
Cruise-In II Veteran
I would think he would call you back for $8000??????
Old Sep 17, 2001 | 07:18 PM
viper8789's Avatar
viper8789
Default Re: Carroll Supercharger !!!!! (Shinobi's97)
Thanks for the reply.......I'm going to either spray it with a 50 shot or water injection I guess.........
Old Sep 17, 2001 | 07:33 PM
thekev_2000's Avatar
thekev_2000
Sorry to hear about your problem. I agree it gets frustrating dealing with the lady on the phone, (Sheryl I think :rolleyes:). I told her when I was ordering my system that wanted to speak with him and unless I spoke to him I would call back every ten minutes. I do not know if this will help but with my system, which does include the gaseous injection, they recommend increasing changing the gap to make it cooler. Just and idea... :confused:
My car just was fired up on Saturday, I'll post if I have any issues! Good Luck...
Old Sep 17, 2001 | 07:35 PM
Mell's Avatar
Mell
viper8789
Did you make some dyno runs and reprogram mixtures etc. to accomodate the new supercharger?
Mell
Old Sep 17, 2001 | 07:37 PM
viper8789's Avatar
viper8789
Default Re: Carroll Supercharger !!!!! (Mell)
no dyno runs yet.......ran it on the laptop for air/fuel readings.........
Old Sep 17, 2001 | 07:43 PM
99 Corvette's Avatar
99 Corvette
Where is the best place to get a supercharger. Websites please?
Jerry
Old Sep 17, 2001 | 07:50 PM
Mell's Avatar
Mell
Default Re: Carroll Supercharger !!!!! (99 Corvette)
Try http://performancetechcenter.com/
Please NOTE that their website is down switching servers and should be up soon. You can call Geoff at 847 228 7256 more info. He really stands behind his cars and gives good customer service.
Mell
Old Sep 17, 2001 | 07:58 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In III Veteran
Did you have any PCM programming done?
RG
Old Sep 17, 2001 | 08:24 PM
thekev_2000
Default Re: Carroll Supercharger !!!!! (RG in Dallas)
Reprogramming of the PCM is a standrd part even with Carrolls kit. The wild card is if you changed something from what the PCM was expecting;, you ordered a stage 1 kit and when it was reprogrammed it is not accounting for an aftermarket exhaust and air intake.
I was VERY VERY concerned about this when I purchased my system and did a lot of research with Nick at ARE, Mr. Carroll and Brian @ VetteWrench. I will see once my car is on the dyno. As I said before good luck
Old Sep 17, 2001 | 08:35 PM
viper8789's Avatar
viper8789
Default Re: Carroll Supercharger !!!!! (thekev_2000)
let me know how yours works out..........thanks
Old Sep 17, 2001 | 11:19 PM
Jimmy O's Avatar
Jimmy O
Cruise-In IV Veteran
I have a carroll system and the car runs great! On the first run on
the dyno my car had a little detonation but still pulled 404 to the wheels.
After making adjustments the car has to be on a dyno do make these
correct adjustments. The correct fuel adjustments were made, no detonation
and 410 rear wheel hp. Also the reason there is no intercooler on carroll kit is
because his stage 1 is only 6 psi of boost, if intercooled you would have a power loss! Jeff at Performance Tech in Elk Grove installed mine. Most of the
intercooled superchargers run 7.5 to 10 psi! Thats why carroll's stage three
uses water injection with 9 psi! Don't panic your car just needs adjustments!
Let me know what happens!!!!!!!!! Jimmy O :smash:
Old Sep 18, 2001 | 12:08 AM
Racer's Avatar
St. Jude Donor '11
Actually Jimmy, you are not quite right. Performance techs Supercharger kits are running 6 lbs boost intercooled and putting around 450 RWHP.
Old Sep 18, 2001 | 01:58 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
viper8789, I hate when people don't call you back! It has been my experience with Greg Carroll that one needs to be persistant in their calling, you will get him. As Jimmy said you need to have it on a dyno with an experinced computer tuner to really get it right. Before you can tune the car you should make sure you have sufficient fuel pressure to go along with your increased air pressure. If fuel pressure is dropping off this will give you detonation. As far as water injection I heard this is ok but not as good as an aftercooler. I am presently adding a custom aftercooler and oil cooler to my Carroll kit as well as a smaller pulley for increased boost. The fuel system is very important on SC application. I had to add a boost-a-pump and rebuild my fuel pump to keep the steady flow of fuel,not to mention 42# injectors.
Stay focused,
JB
Old Sep 18, 2001 | 10:33 AM
TomC5's Avatar
TomC5
viper8789,
I would also have to suggest that you call Geoff at Performance Tech Center. He definatly has the knowledge to help you and I know he has corrected a few of the Caroll kits. I can tell you that his kit on my car has performed flawlessly for over 10,000 miles. There is a lot to getting the PCM correct and Geoff seems to have it dialed in.
Tom
Old Sep 18, 2001 | 10:41 AM
viper8789's Avatar
viper8789
Default Re: Carroll Supercharger !!!!! (TomC5)
nice car.....been to the track ? Where is Perf.Tech Center ? Do you have a phone # ? Thanks........
To Carroll Supercharger !!!!!
Old Sep 18, 2001 | 11:37 AM
Vette-Racer's Avatar
Vette-Racer
I think I will hold off on that mod for awhile :(
Old Sep 18, 2001 | 12:51 PM
Da Kind's Avatar
Da Kind
Default Re: Carroll Supercharger !!!!! (Vette-Racer)
Great tuning and better fuel delivery will be the key.
Old Sep 18, 2001 | 01:04 PM
TomC5's Avatar
TomC5
I have not been to the track yet because I am not sure I want to put in a rool bar yet. I am sure it will do well if I can get it to hook up.
You can reach Geoff at Performance Tech Center at 847-228-7256. PTC is located in Elk Grove Village, IL but he has serviced cars from across the country.
