Tire Pressure Indicator
Old Oct 19, 2006 | 03:02 PM
daddyrich's Avatar
daddyrich
Default Tire Pressure Indicator
For the past two weeks whenever I start up my C5 and drive, my gauges indicate low air pressure in my tires. Sometimes only one tire is low and other times all four show low pressure. I know for a fact this is not the case, and outside air temp is not a factor. So I do the reset deal and all is cool until I start up and go agin. This is the first time I have had a little time to research this problem on the forum. Can anyone enlighten me whreras this is a easy fix or a dealer repair. Thanks for any input.
Old Oct 19, 2006 | 05:22 PM
Oldvetter's Avatar
Oldvetter
What is your air pressure? The low pressure warning comes on at 26 psi. Mine came on one cool morning. You loose about 1 psi for every 10 degree drop in temperature.
Old Oct 19, 2006 | 07:19 PM
daddyrich's Avatar
daddyrich
I don't think it has to do with outside temp, been near 750 deg every time I have driven the car. Other replys to my problem seem to indicate low battery on my sensors. Thanks for your input.
Old Oct 20, 2006 | 12:31 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
750 degrees F?
The tire warning comes on when pressure gets down to 25psi...
Old Oct 20, 2006 | 12:35 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You just posted this and got many replys pointing to your problems...
why are you posting again... ??????? the same issue???
Dont you believe us, or are you waiting for an answer that you like?
To Tire Pressure Indicator
