Unlocking Torque Converter Question
Old Oct 19, 2006 | 05:38 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default Unlocking Torque Converter Question
Okay, I just had a brand new torque converter and transmission (built by Rodney at RPM) installed last week. Due to some tuning issues (clarified this with Todd at RPM), the TC is unlocking at cruising speeds.
Okay, the tuner I am having look at it is about 2 hours away, is it safe for me to drive my car to him?
I really need to get my car re-tuned and this will require driving it to the tuner, because I do not have a trailer or a truck.
Thanks in advance,
Micah
Old Oct 19, 2006 | 07:34 PM
tiojames's Avatar
tiojames
Default convertor
I would keep checking the tranny temp on the way to the tuner. I would also check with the who built the setup to see what they say about driving it the way it is.
Old Oct 19, 2006 | 09:37 PM
Jettech's Avatar
Jettech
I had the same problem after my rebuild and Vig 2800 install. Had to adjust the misfire tables to 32000 if I remember right. Jimmy blue on ls1 tech has the correct info for this. This is a common problem with a high stall converter. This fixed my problem. Hope this helps.
Old Oct 19, 2006 | 09:46 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
This is what I am hearing, I am going to get it all worked out next Tuesday! I can't wait.
Micah
Old Oct 20, 2006 | 08:34 AM
patton's Avatar
patton
St. Jude Donor '09
like the man say check temps and dont force a down shift ya might get a check engine light going there that is norm
Old Oct 20, 2006 | 09:30 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
If you do drive it to the tuner just take it easy and cruise it! Then once it is fixed have some fun! As stated above watch the tranny temps on the way and all should be okay!
Thanks,Matt
To Unlocking Torque Converter Question
