? up grading new tires size.
Old Oct 20, 2006 | 11:46 PM
wolfman04's Avatar
wolfman04
Default ? up grading new tires size.
Thinking about going with 295/35 18 and 265/40 17 will they fit on the stock rims and how much wider are they then stock size?
Old Oct 21, 2006 | 06:14 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Have you tried a search as this has been discussed ad nauseum?
That having been said, yes Z06-sized tires will fit coupe-sized wheels. IMHO it is not an ideal fitment, but many people here say they run this combo w/o problem. How hard they drive them I don't know.
As to your question of how much wider..., I don't understand what you're asking. The Z06 tires are 20 mm wider than the coupe's; the Z06's wheels are 1" wider than the coupe's.
Old Oct 22, 2006 | 11:33 AM
shurite44's Avatar
shurite44
Yes they will fit.
Old Oct 22, 2006 | 12:23 PM
LAYNLOW's Avatar
LAYNLOW
I have the Michelin PS2 295/35/18 on the rear of the C5 and they work fine. They stick out from the rim edge some what, but not offensive looking.
Good luck!
To ? up grading new tires size.
