Oil Pan Help!
Old Oct 21, 2006 | 03:21 PM
happa's Avatar
happa
Default Oil Pan Help!
Ok very weird thing has happen. I have a oil leak on the back side of the motor. Thought it was the rear main, but the 2 small bolts that are on the bottom (right near the bottom bell housing) were loose. I tried to tighten them up, but it would not tighten. Threads looked fine on bolts so its stripped out. Weird??? how do I take the oil pan out? Thanks for the info!
Old Oct 21, 2006 | 04:20 PM
djengr's Avatar
djengr
I would investigate tapping the treads first. You should be able get a decent tap and die set at most automotive or hardware store. Maybe go one or two sizes over. good luck
Old Oct 21, 2006 | 04:57 PM
msghuff's Avatar
msghuff
Are you talking about the long bolts that hold the pan to the rear cover?
Old Oct 21, 2006 | 05:25 PM
happa's Avatar
happa
yes they are very long, used a 10mm to take out.
Old Oct 21, 2006 | 09:27 PM
msghuff's Avatar
msghuff
Thought so. Mine wouldnt tighten so I bought 2 new bolts and it worked.. but i replaced the cover 2 weeks later when I did the rear main seal.
I would try a new bolt wrapped with thread tape and see if it works
Old Oct 22, 2006 | 01:58 PM
happa's Avatar
happa
Thanks Man, going Monday to see my bolt guy. Hope it works. Thanks Again for the help!
To Oil Pan Help!
