Quick Door Question
Old Oct 23, 2006 | 12:35 AM
B-rent's Avatar
B-rent
Default Quick Door Question
I need to replace my passanger door on my black 98 vert. I found a black 02 Z06 door already painted (assuming it fits?). Would it still need to be repainted after the moulding is taken off or do you think the fading/glue shouldnt be a problem?
Thanks,
Brent
Old Oct 23, 2006 | 08:52 AM
B-rent's Avatar
B-rent
Do the '02's have the same door and are there holes behind the molding?
Old Oct 23, 2006 | 09:03 AM
Lestat52's Avatar
Lestat52
The only difference I can think of would be the 2002 will not have the keylock in the door handle. You could probably move that over from the over door. The Body Side Moldings are attached with adhesive tape
Old Oct 23, 2006 | 09:10 AM
B-rent's Avatar
B-rent
Do you think that the door would still need repainting or would a good compound + buff job get the adhesive off and make it look ok untill I get the whole car repainted next summer?
Old Oct 23, 2006 | 11:38 AM
Hatdude's Avatar
Hatdude
That really depends on the condition of the replacement door and the rest of your car. If there isn't any fading of the paint you should be able to just remove the BSM and clean off any remaining adhesive.
To Quick Door Question
